After doing some jumps at a bmx track for the first time, everything seemed fine and we went to a soccer field to continue bashing. That's when I noticed the back left wheel was wobbling, it got worse and then the tie rod came loose basically petting the wheel fall 90 degrees. The drive shaft was just laying there in the dirt and I found that the nut holding the tie rod to the rear shock tower just fell off.
I fixed the tire rod but now there is severe real wheel wobble on both rear wheels. I cant see what is wrong, I have no where to start?
The car does not seem driveable as I think the entire rear end will loose all the nuts and screws with this vibration.
This kraton is running on 6s and is completely stock
