jschlosser0405
Hey guys, I ran into an issue tonight fitting the grubloc PPS mount to my V4 Noto. I planned on changing the center diff to an EXB that I fitted with the HR 29mm diff case. It doesn't fit into the PPS mount unless I loosen the screws which obviously wont work. So I thought maybe its because its a HR. I just tried fitting the regular plastic cased EXB diff, still does not fit. Looking like I am about 1mm too long from bearing to bearing. Am I missing something? EXB diff with HR case is 32.95mm, reg EXB diff is 32.75mm, reg 6s plastic diff is 31.90mm. All measurements are bearing face to bearing face. M2C chassis that looks perfectly straight. Anyone run into this or have any input?
