bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
Remove the spacers behind where the pillow balls screw onto the A-arms, both top and bottom.Is there something that can be adjusted to help reduce a tendency for the dogbone from slipping out of the cup on the front. Was doing some mild jumping and it kept slipping out on my Kraton. I need to replace the cups because of the wear, but wondering if there something that can be done to prevent???
I tightened the set screw on the inside of the a-arm that decreased the angle so the a-arm can't travel as much in the negative. Softer shocks??
