What's up everyone,
I have a V5 Kraton running on 6s. The motor is getting too hot for my liking. Unfortunately, I cannot find my ir temp gun so I cannot provide exact numbers (I have another coming it should be here tomorrow). I am looking into motor fans and heatsinks. I have a couple of questions.
The yeah racing/power hobby dual fan setup seems to be one of the better options. From what I am reading it seems like the fans they come with aren't so good. There are a some aluminum bodied 30mm fans that have a higher max rpm that seem like the way to go. Is there a better dual fan setup than the yeah racing? I know that the stock motor is slightly smaller than the yeah racing heatsink but I was planning to use some thermal pads anyway to aid with heat transfer .
The second question I have is how necessary the heatsink really is. Would dual 40mm fans mounted without a heatsink do a better job at cooling? Doing some research on this topic there seems to be some debate as to whether or not these small heatsinks do much. In threads I've read on this and other forums there are some that say that the motor can itself enough of a heatsink and that airflow is all that's needed. However the stock V5 motor is smooth, does that only apply to finned/ribbed motors?
Thanks,
Crash
Thanks,
Crash
