Kraton V6 kraton, how to tell if I need to shim diffs?
SpeedyJ
  2. Vorteks
Got the new v6 kraton, haven't run it yet, just making sure everything is good first. How do I tell if the diffs need shimming? When I roll the rc it makes allot of drive train noise and has a decent amount of resistance.
Thank you!
Wouldn’t check them until you’ve run through a couple packs to let everything heat cycle into the composites.
First 6/8S arrma?
First 6/8S arrma?
I had a used kraton exb a while back but I didn't get much experience with it before I had to sell. This is my first new Arma kraton 6s
What @Garcbomber said, run a few packs first THEN check it. The diffs need to break in first.
Then you can check for play in the internal gears, cups and ring/pinion.
Ran a battery pack through it today. Man this thing is wild, couldn't imagine it needing any more power!
