Kraton V6 XL kraton
Sounds like a new one, project, for sure. Sub'd
But here's an idea. I extended the rear body mounts on my custom chassis 352 Outcast. I machined delrin acetyl 25mm blocks with through holes & longer 12.9 screws, to to make up the difference & not cut holes in the body. An idea like this could be done with 3d printing. Look closely at the posts. They are mounted on 25mm solid delrin blocks. Should hold up just fine.
The body posts themselves are aftermarket aluminum.
I have a design already in mind..
Recently got all the parts
and just need to get my turd-ed damn printer back up & running And recalibrated...
to make some prototypes.
The main issue is that the new clipless system have spayed out posts -that prevents you from "just screwing in longer screws" Straight into the posts (or post holder)
They are now in an odd angle.
You got this. Didn't you just get a Kraton clipless body?
