Granite Velineon Voltage
ARM(a)&LEG
New Member
I was so impressed with mark’s GV on YouTube I had to try the same config myself.
So here she is:
$89 from Horizon
Spektrum S650 servo
Traxxas Velineon 3s system
4ch mini radio and rx(Amazon special)
25t pinion
6200mah 80c 2s lipo
Krylon Short Cuts flat white.
-A couple of light coats of Krylon.
-Tubbed the chassis to accommodate bigger batteries-originally wanted to put the esc and rx in there too but no room.
-Reamed the motor compartment to accommodate the Velineon 3500.
-Velcro’d the ESC and rx in their respective areas.
Ridiculous amounts of power.
Comfortable control at a 1/4 throttle.
Throttle and vector management critical otherwise it just spins and flips.
No stripped gears-Velineon system operates smooth, quiet and efficient.
I LOVE THIS THING!!
Soo much fun!
The GV IS DEFINITELY worth putting some time and $ into-it’s cheap and tons of fun.
Next upgrades are ceramic bearings in the transmission/diff and Fluorescent yellow over the white base coat.
3S maybe?????(yikes!)
Feel free with any ?’s or thoughts.
Thanks for looking.
That is a crazy amount of power you have put into that truck! Let us know how it holds up.
I have worked on the Granite Voltage's a bunch.. Running stock brushed. :oops:
Btw, looks good!
Just a heads up normal spray paint doesn't stick to Lexan very well, it will crack and flake off. And normally you paint the inside of the body.
Btw, looks good!
Thank you!! Ran 2 packs already. I’ve read a lot of guys shred their stock drivetrains once they convert to brushless. So I’m going real easy on the throttle!
Yeah I know. Just trying to make this thing more visible is all…it gets small real quick! I’ve painted the exterior of a couple of lexan bodies with Krylon and it holds up surprisingly well. Most of the flaking occurs by the body clips.
