SeaOfChaos
- Typhon 3s
Tighten adjustment nut all the way in after all. I ran the Typhon and this method works best. Any backing out of adjustment results in easy slipping. The method described in the original.post results in almost instant slip. My bad for not trying it before posting.View attachment 188417View attachment 188419View attachment 188420
Vendetta 50t slipper fits perfectly. It has to be put together around the motor mount. Unlike Typhon 3s V3 stock 57t that slips right in. To adjust I inserted the stock slipper into the back of the new slipper and turned the two against each other making sure only the stock on would slip. Then backed out the adjustment nut, twisting the two against each other until the the stock clutches slip became smooth and fluid. The Vendetta clutch is not slipping at any point during the adjustment. Stock slipper is one quarter turn out from full stop. Vendetta slipper nut is not Fully tightened, just enough for locked.
