- Infraction
- Kraton EXB
- Notorious
- Talion EXB
- Vendetta
Everyone's out there building speedrun vendetta's and I'm just here parking lot racing.
This is a casually competitive parking lot road course racer for neighborhood races. I'm trying to squeeze all I can out of the suspension tuning, tire options, and everything this car is able to bring to the cone course. I think the vendetta is a fantastic car that a lot of people are sleeping on. Get out there out put down some laps!
Zeee 5200mah 80C
Spektrum Firma 100a ESC
Spektrum Firma 3200Kv 3660
Spektrum S651 servo
Hoons elevens white
HR aluminum pivot balls
Servo saver delete
Setup
ESC
punch: level 2
brake force: 75%
Gearing: 50/20 mod 0.8
Front
ride height: 13mm
camber: -2.0 degrees
toe: +3.0 degrees
gap from top of shock to top of spring adjuster: 2.0mm
Rear
ride height: 16mm
camber: -1.0 degrees
gap from top of shock to top of spring adjuster: 3.5mm
link position: upper, outer
The first thing I wanted to address was the amount of slop in the suspension linkage. I replaced the stock plastic pivot balls with hot racing aluminum pivot balls. They definitely helped tighten it up and they look great too.
Zeee 5200mah 80C
Spektrum S651 servo
Hoons elevens white
Servo saver delete
Setup
ESC
punch: level 2
brake force: 75%
Front
ride height: 13mm
toe: +3.0 degrees
Rear
ride height: 16mm
