Vendetta esc swap
Falcon730
  1. Felony
  2. Limitless
  3. Kraton 6s
  4. Kraton EXB
  5. Mojave
  6. Typhon TLR
  7. Vendetta
I put a 150a spectrum esc in my vendetta. I can't seem to get bit to calibrate. Only change is the esc.
You mean can't calibrate the Throttle endpoints with the radio?
1st off you need to switch rotation of motor on esc...motor sits in car other direction than it did in 6s ride...then calibrate 👍👍
After doing what K-BASH recommended, check to make sure the throttle trim knob is set exactly to the mid-point. If the throttle trim is off center even by a little bit, the ESC won't calibrate correctly. I had it happen once to me: I tried at least half a dozen times to calibrate the throttle, all unsuccessfully. Once I reset the knob it calibrated easily.
