zizi8862
Sorry if this is discussed quite a lot. I still don't quite understand the concept of venting tires on instead of just having the stock wheel vents. Wouldn't water and dust get in if vented on the tires??
Dust is sort of the same concept as water, it does get flug out the holes as well.I understand with water that it will get slung out but won't dust or dirt get trapped between the rubber and the foam??
Don’t underestimate the weight of the air inside spinning too. That air trapped against the tire has force too when spun at high speeds. People assume air is weightless, but that’s when it’s not moving. Ever tried to stand in strong winds? There’s mass there. Otherwise hurricanes couldn’t do the damage they do. You are starting a mini hurricane in your tire and if that air can’t escape, it will blow out your tire instead. Water and dirt of course have higher densities so they have a greater effect. But it’s all the same results.
I use an EC5 connector bulletSo I'm looking to vent my tires on the outside and was wondering what kind of tube to get for cutting the hole. Is it a specific tube that's available at hardware stores? TIA
Got a few EC5 connectors around. Didn't even think to use those. Thank you!I use an EC5 connector bullet
But any 3/16” or so, tube will work.
When you say actual bullets, you mean to shoot a round through the tire, right??Actual bullets work too, brass tubing, an old eye poker antenna, a soldering iron, lots of ways.
Yep any antenna should work. Just get a nice flat end and sharpen it with a good knife. Pop some holes in the treads, tape the rim holes, and get out and bash.When you say actual bullets, you mean to shoot a round through the tire, right??
I don't have any bullets/casings that would be small enough but I think I've got old rabbit ear TV antennas somewhere that have the telescoping antennas.
