Very dissapointed
Discussion in 'Granite & Senton Mega 4x4' started by trout74, May 26, 2018.
  1. trout74
    trout74 Well-Known Member
    May 24, 2016
    55
    54
    Arrma RC's:
    Kraton
    im an ARRMA fan boy through and thourgh. I have 2 kratons and 2 outcasts all modded to the gills, and a youtube channel to back it up ( trout74) . I bought a granite 4X4 mega for my 7 year old to play along with me. Totally stock running a 2S lipo. First pack an 8000mah 2s lipo and it thermal shutdown in 15 minutes. let it cool off and 15 minutes later thermal again. Very dissapointed. First time ARRMA really pissed me off. I have to buy a real ESC to run a stock brushed motor???? SERIOUSLY? ARRMA this is terrible.
    TROUT
  2. GuyFromCanada
    GuyFromCanada Premium Member!
    Apr 30, 2018
    102
    10
    Ottawa, Ontario
    Arrma RC's:
    4x4-Mega
    FWIW, I run 5300mA NiMH packs through my Granite's, and the motors have gone before the ESC...maybe the heat sink is poorly attached?
  3. trout74
    May 24, 2016
    55
    54
    Arrma RC's:
    Kraton
    I ended up installing a Castle Sidewinder3 and 4500KV sensored green motor. Life is good. Used stock 14T pinion, so its not really much faster, just way more efficient.
    Trout
  4. GuyFromCanada
    Apr 30, 2018
    102
    10
    Ottawa, Ontario
    Arrma RC's:
    4x4-Mega
    I'm interested in the same idea...is it the SCT version? Did you consider the 3800kV motor?
    #4 GuyFromCanada, May 26, 2018
  5. trout74
    May 24, 2016
    55
    54
    Arrma RC's:
    Kraton
    3800 would be fine too, its the sensored one, I had it on hand. So I just popped it in.
    Trout
  6. GuyFromCanada
    Apr 30, 2018
    102
    10
    Ottawa, Ontario
    Arrma RC's:
    4x4-Mega
    That's what I was thinking...I need to buy a set of pinions when I get a new power system. I guess this is where things start getting interesting.
  7. trout74
    May 24, 2016
    55
    54
    Arrma RC's:
    Kraton
    yeah it woke it up a bit. Could go up a few in Pinion and get some good speed, but its for my 6 1/2 year old, so hes good.
    Trout
  8. ThatDrewGuy
    ThatDrewGuy Premium Member!
    Apr 18, 2018
    62
    25
    Chicago Area
    Arrma RC's:
    Granite, Talion, Typhon
    Would a good motor fan solve that problem you think? They are cheap, but made a significant difference (30 degrees) on both my Talion, and Typhon. I was running 190-200, and took it down to 165 which seems like a sweet spot for the 90+ weather I’m currently running them in.
  9. Jerry-rigged
    Jerry-rigged Premium Member!
    Premium Member Excellence Award
    Apr 27, 2016
    1,623
    907
    Texas, Baby!
    Arrma RC's:
    Kraton, Typhon, 4x4-Mega
    When I was running the stock power system, I had the same issue - about 15 minutes in, the ESC would thermal, right at 175f. The motor would be around 190f-205f. Stock, neither the motor or ESC has a fan, and the ESC heat sink is kind of shallow. Fans might help the situation, but...
    I am not sure what Arrma should have done to fix the situation. 91/14 is already pretty low gearing, and a 550 /12t is about the most power you can get (cheaply) out of a brushed motor.
    For sure, the Mega 4x4 platform just begs for a brushless system. And a better diff input. The rest of the truck is solid. If/When Arrma releases that version, it will be a killer truck!
  10. Bri26
    Bri26 Well-Known Member
    Aug 23, 2016
    90
    28
    Arrma RC's:
    Fury
    Do you think the electronics aren't getting good airflow with the tall chassis dirt guards in the front?
    Best regards,
    Brian
  11. Jerry-rigged
    Apr 27, 2016
    1,623
    907
    Texas, Baby!
    Arrma RC's:
    Maybe less airflow than without the guards, but I suspect that even if the guards were removed, you would still have heat issues. A fan on the ESC and motor would also help, but the ESC and motor would still be overworked. The truck just needs more power than you can get from a brushed motor. Or it needs lower gearing.
    KMS likes this.
  12. trout74
    May 24, 2016
    55
    54
    Arrma RC's:
    Kraton
    Agreed. It needs brushless setup and better esc. We’re many many packs in on 2s and we’re good to go.
  13. Jfpryde
    Jfpryde Well-Known Member
    Feb 12, 2017
    29
    18
    I don't know that many entry level brushed rigs do any better. I had similar issues with ECX brushed stuff and my older rustler until I upgraded to the beefiest brushed esc I could find. I woulda just gone brushless on that one if it weren't for my kiddo. I didn't want him to have too much power.
  14. Jerry-rigged
    Apr 27, 2016
    1,623
    907
    Texas, Baby!
    Arrma RC's:
    If you don't want too much power, but are tired of burning up brushed motors, look into one of the "F540" motors - they are 380L (long) brushless motors, with big cooling fins. Power is similar to the 12t 550 motor in our Granite mega 4x4. I ran one in my Mega 4x4 for a few batteries, it worked well, and kept the speed similar to stock.
    The motor I have is a Racerstar, but there are a lot of different ones out there... Here is a longer write up I did on my F540-
    https://www.rcgroups.com/forums/showthread.php?2713040-Racerstar-F540-45A-ESC-combo-Review
  • Welcome to Arrma Forum
  • Disclaimer
