Seba910
- Kraton 6s
Hi all i'm new to the forums so thank you for having me
I'm the proud owner of a new Kraton 6s v5 and am absolutely in love with it, however I have one slight issue.
I purchased with the truck 2x prime 3s 5200mah 50c lipos they were $85 Aud each so on the budget side for batteries.
My problem/Question is: Are 6-15 minute run times normal for the truck? by no means am I running it "flat out" more than I'm running it normally... Reading other posts I am seeing people get close to 30 sometimes 40 min runtimes on similar spec batteries. Is this normal for the truck ? Is this normal for cheap budget batteries ? Is there a battery issue ?
Car drives beautifully during the time and have no complaints, just +- 2 hours to charge 2 batteries (from single channel charger) for a max 12 min run time is getting annoying.
Ill also add that when charging these lipos, when they reach voltage cut off of 12.6v the mah goes up to -+ the 4000 mah mark.
Is this normal? When the batteries reach there voltage dischage cut off, they hold Mah? 1000 mah roughly?
Is this why I never see them charge to 5200mah on my charger?
sorry for the long post haha
Cheers in advance for the help
