Shimming, as I have learned from a lot of people here and some good videos, takes some time to get the right feel. It will not resolve all issues, but it sure helps.
When I shim a diff, I like it fit and snug. I do have the stock plastic diffs. I know the next time I check them, they will be a bit loose, so I may need to add a 1mm shim. For example, I shim a rear diff where there is no side-to-side movement if possible. I will go tighter but not binding before going loose, or I cannot remove the little tick. As for the input gear, I like to have the diff in my hand so that when I shim the input, I can see how much of the input teeth are pushed up/inward toward the diff. I will add shims to get the input closer to the diff. Before I am done with the diff in hand, I put the diff cover plate on and tighten the 4 screws to make sure there is no binding. It's a feel and a sound you will grow to learn when it is correct. I certainly like to hear more of the metal sound of the gears when well meshed. Again, it is not binding. If it is a bit snug again, it's a feel I know; I will keep it there since it will wear in. It's never hard to turn or bind.... It's not a loose free turn or free spin, either. For my 6S bashers, FT, Talion, Kraton, etc, with plastic diffs, it has been good once I got shimming down.
All my Losi rigs were bad as stock and stripped gears until I shimmed it the way Losi should have. In some cases with the best shimming, a metal diff case is needed. It certainly was so with the 1/5 Losi DBXL-E plastic case, which had too much flew.
Your style with your rigs will help determine the next step if shimming does not get you there.
Brother, this speaks volumes based on how well you bash!!! Props
