Infraction Vitavon question…
AjDale
I have vitavon hubs on my infraction f/r. A rear inner bearing seized up which I believe is the “oversized” bearing at 24x15x15mm, is there any other bearings that fits? Besides ordering directly from vitavon?? Was hoping for a quick fix without having to wait around just for some bearings… thank you!
I've never went through an inner HD hub bearing, but I grease with diff servicing. How fast has it been out of curiosity?
Just looked at my purchase history and these are still new in package from over a year ago
https://www.ebay.com/itm/154957872335
Had them on my Mojave before swapping them to my infraction today. Definitely went through dirt and mud a couple times and seized it right up. As for the sizing that I got, that’s directly from their website so I’m just going off what’s given to me. I’ve only ran them maybe 3 times before I kept thinking it was diff issues. But those bearing will fit inside the Vitavon hubs? Just wanna make sure…..
If you have a caliper or small enough bore gauge you can double check, seems like the arrma Alloy standard HD inside hub bearing size.
3mm OD increase over the composite molded with larger internal dual race ball bearings.
Mannn🤦‍♂️ I’m just putting things together lol. So vitavon has it as 24x15x5mm and says “instead of stock bearing 21x15x4mm” so I looked that bearing up and found it as 15x21x4mm. So assuming they just put their numbers differently it should be “15x24x5mm”. Therefore the bearings you sent will work as well as my shop having Traxxas bearings that exact size….
I order bearings right off Amazon 25x15x5 and can get them next day. They have always been as good quality as Jim’s or Fast Eddy. Ceramic bearings are a different story.
