CARPJR
I'm runing an Infraction. Using Two Cheap 3S 80C 5200MAH batteries in series I to a Spektrum 160A ESC (out of a Kraton) into a Castle 2200kv motor.
While doing short speed runs I'm getting an cutout at wide open throttle. My data shows minimum voltage dropping to around 16 volts.
Is my cutout caused by a couple bad battery cells? Is that unusually high voltage drop?
Running 29/34 gearing - it's a very heavy load.
Or is this just too much for that ESC?
