N0isyknuckles
- Granite
I needed to drain a 3s battery so that I could place it into storage mode so I cracked out the granite. This granite is on it’s 3rd ESC in the past month...currently has a 120blx on it.
i decided to run a Voltage alarm on it. The batteries were around 4.05 volts when I started and I set the alarm to 3.6. A few warm up passes and then gave it about 90% throttle on a straightaway. It didn’t take long and my alarm went off. I checked the voltage on the batteries and they were around 3.9.
I kept setting the alarm lower and lower and would consistently get alarms at .3-.4 volts at rest above the set voltage on the alarm
Is this normal for batteries to sag this much when under load? and how long do esc’s average volts to determine LVC? I’m assuming some of this was my problems with the blx100.
