Hello all! If you haven't seen my introduction post I'm a newb here so go easy on me! I purchased a Vorteks and am having a blast with it but noticed very short run times with my Socokin 6600mAh battery so I did a little investigating.
Here's a link to the battery I tested. When I bought it last week it was $41.89 for two of them. I soldered on a EC5 connector.
Link deleted - Not sure if that would be a forum violation and I want to be careful as this is my 2nd post!
After fully charging to 4.2V I got 10 minutes 10 seconds run time. Half grass, half asphalt, not going extremely hard. After resting the battery for 10 minutes it showed a charge of 3.73 volts on each cell. That seemed quite high to me for a LVC value. I charged the battery back up to 4.2 volts and only 2525 mAh was required to charge the battery. Less than half of the rated capacity. Okay maybe I got ripped off and they rated the battery on a "death cycle" from like 2.8 volts to 4.4 or something crazy.
I set the ESC into NiMH mode to effectively disable the LVC. As you know the Vorteks ESC has no LVC programmability.
Using a multimeter I ran the car, all grass, quite hard for 10 minutes, checked voltage, ran a few more minutes, checked voltage, etc.. I didn't write those voltages down. But I did stop the timer each time I stopped to check voltage of the battery pack (with a multimeter). The car ran for 17 minutes this time and the cell voltage was about 3.2. I didn't want to go any lower for fear of damaging the ESC and/or battery. 10 minutes later after plugging it into the charger the rested voltage was 3.33 volts/cell.
Next I charged the battery and what do you know? 6054 mAh went into that battery. Only 10% less than the rated capacity. I also took voltage and mAh readings during the charge cycles as I was very curious as to the charging behavior. You can see my graph below.
My conclusions are as follows. As I wrote above I'm a newb, just trying to be helpful. This data is obviously for my battery but I would expect most Lipos to behave in a similar manner but only further testing would confirm or deny that hypothesis.
1. The LVC on my Vorteks is set ridiculously high. Over half of the battery capacity is being wasted.
2. In my opinion a good "rested cell" discharge voltage is about 3.50 to 3.55 volts, which would probably result in a max discharge of about 3.2 or 3.3 volts. Going any lower does not result in any significant storage capacity.
3. Charging to 4.15 volts wouldn't result in a significant reduction in capacity either, that is if you wanted to "baby" your battery.
4. A good portion of the "meat" of the battery capacity, nearly 1/3 of it is between 3.6 and 3.7 volts. The Vorteks LVC completely wastes that zone on the graph. Note that this conclusion assumes symmetrical charge/discharge behavior, which may be completely incorrect but I think is a logical assumption.
5. I charged at 3.0A for a C charging rate of 0.496 (based on 3000/6054 mAh), which would theoretically be 121 minutes to charge. The actual charge time was 125 minutes, which would account for the ramping down of amps at the end of the cycle during the cell saturation at 4.2 volts. It's nice when experiment and theory agree
6. The 2425 mHr charge I obtained with the Vorteks 3.73 V LVC is just about what you would expect if you look at my graph. Meaning if you charged from 3.73 V to 4.0 V from my graph you'd see about 2800 mAh going into the battery, pretty close to the 2525 I measured on my initial test.
Next I e-mailed Arrma tech support and gave them a detailed explanation of my findings. The representative, who was very nice told me the LVC in the ESC is set by the manufacturer and Arrma doesn't know what it is and can't change it. I didn't want to push him because as I wrote he was very nice and it was obvious that this was the extent of his ability to comment on this issue.
Next I ordered a SPMXSE1130 ESC for my Vorteks so I can set my LVC. 10 minutes run time to 17 is a huge jump and it would probably have been closer to 20 minutes had I been running it easier as in my initial test. There are so many things "right" with Arrma that this isn't a huge deal for me. It would be nice if Arrma could make this LVC adjustable through a firmware update. Or perhaps I got an ESC that was programmed incorrectly or is malfunctioning?
