Vorteks Vorteks tyres
Holme-86
Hello. Does anyone have any suggestions on good tyres to put on my vorteks that dosent wear out as fast as the stock ones? Ive maybe run about 8 batteries and the rear tires are now slicks.
What surface are you running on? The wrong tire for the surface will cause it to wear much faster than normal and underperform
I got a set of belted badlands ST and they were great. Then for fun I put the new stock big rock tires from my wife’s car cause I put granite tires on it. I absolutely love the big rock tires on my vorteks…they are just fun. Great combination of traction and lack of traction if that makes sense.
I wanted a bit more clearance also as we don’t run too much flat or Road.
Mostly gravel. Sometimes asfalt
Did you also change to a smaller pinion gear since the tires are bigger?
