Infraction Wanting to upgrade the motor fan
basher27
I’m wanting to upgrade the motor fans on my Krayton and infraction 6S. Would something like this be a good fit for them? They are 35 mm or would a 40 mm fan fit the bolt holes on the stock heat sink?
https://a.co/d/gQu7UDx
A smooth can, like the factory 4074 Spektrum, I'd keep the heatsink. A single 35mm aluminum Rocket fan will bolt right on the factory heatsink & move 2xs as much air.
I agree that’s what I’m leaning towards
I'm not sure where you live or how you bash. The Infraction 6S can get HOT when drift bashing, and none of those Rocket or 35mm fans helped me, even though I tried a lot.
I am not recommending this, but Game Changer fans were the only fans that kept low temps while bashing. It is the only rig that has them. They are expensive, but I am just sharing that.
Kraton and other 6S bashers, I have been very pleased with the cooling power from RCP:
https://www.radiocontrolpower.com/p...l-40mm-high-speed-rc-fan-8-volt-plug-and-play
These 40mm fans do me well here in the US Southeast and blow hard. I like ribbed motors and what I use. I do not need a heat sink and blow directly onto the motor.
Best of luck with a solution (y)
