- Rockaway, New Jersey
- Notorious
- Senton 6s
- Talion
- Typhon 6s
yepare you talking about the red ones?
And the gasket that goes on the top of the cup. Maybe someone has found a rubber seal that works better than the stock gasket
Can it cause any damage running without oil?
I used to fill my diffs nearly to the top of the cup as I observed in a YouTube vid. They always leaked. I realized I was overfilling, not leaving enough room for the planetary gear. I started filling only up to the satellite gear cross shafts and haven't had any diffs leak since. I also use black grease around the red O-ring.On this subject, has anyone researched some different o-rings and gaskets for the Arrma difs? Even after cleaning and shimming my difs, I noticed that the chassis is damp from dif fluid. This is while the truck has been sitting for at least a couple of weeks (too cold to run), and it's only ever been run a few times since new. The stock rings just don't seal well enough, even with 500k fluid, which is pretty thick. Also, for those who use the aluminum dif cups, do you find this to be the same issue?
I just got my v3 Typhon yesterday and took the center diff apart to build my spool and it had basically ZERO fluid in it... I don't know if this is a trend with Arrma but i def suggest checking before running them...
The nice thing about the Arrma cups though, is you have a bleeder hole. If you fill them up high, just remove the grub screw and excess bleeds out. Am I wrong for wanting the cup to be full?I used to fill my diffs nearly to the top of the cup as I observed in a YouTube vid. They always leaked. I realized I was overfilling, not leaving enough room for the planetary gear. I started filling only up to the satellite gear cross shafts and haven't had any diffs leak since. I also use black grease around the red O-ring.
I don't feel it's necessary to aim to be completely void of any air such as in a shock. I think 80-90% full is good enough. Perhaps someone can correct me otherwise but I don't see any gain in aiming for 100% full vs 80-90%. My experience is the internal pressure from aiming for completely full results in leakage. While filling only up to the satellite gear cross shafts may look low, the planetary gear once inserted will displace most of the remaining air, leaving you with a nearly full diff.The nice thing about the Arrma cups though, is you have a bleeder hole. If you fill them up high, just remove the grub screw and excess bleeds out. Am I wrong for wanting the cup to be full?
The issue with the center diff is that the diff cup is plastic and no matter how hard you try it's going to leak.On this subject, has anyone researched some different o-rings and gaskets for the Arrma difs? Even after cleaning and shimming my difs, I noticed that the chassis is damp from dif fluid. This is while the truck has been sitting for at least a couple of weeks (too cold to run), and it's only ever been run a few times since new. The stock rings just don't seal well enough, even with 500k fluid, which is pretty thick. Also, for those who use the aluminum dif cups, do you find this to be the same issue?
I don't feel it's necessary to aim to be completely void of any air such as in a shock. I think 80-90% full is good enough. Perhaps someone can correct me otherwise but I don't see any gain in aiming for 100% full vs 80-90%. My experience is the internal pressure from aiming for completely full results in leakage. While filling only up to the satellite gear cross shafts may look low, the planetary gear once inserted will occupy most of that space.
I switched to an aluminum diff cup with the factory o rings and gasket and it hasn't leaked since.
Only problems I have had with them was when the bearing on the pinion exploded and ate the rear crown and pinion gears. And I snapped a rear outdrive one time. But no leaks or anything else. But that center diff was a thorn in my side, replaced everything and the stupid thing still leaked. It always leaked between the cup and the spur and out of the screw holes.now that you have said that...
