Arrmadog1990
Bought these nicely machines diff lockers and just got them in! Going to try them out in all 3 diffs. If the front scrubs too much when I turn on pavement (not that I do a lot of on road stuff but still) then I’ll leave the center and rear locked and do limited slip in the front. Gotta try all 3 first! Also going to cut down drill bits for the cup pins in the diff and the pins in the hubs will be getting cut down drill bits as well. Drivetrain Should be pretty minus the cup and driveshaft pin wear but that will last longer than these diffs lol. I’ll keep you guys posted. Should be getting some bashing video soon to see how well the cooling system holds up on some jumps!
Pretty solid minus***
