- Nero
Hey everyone.
So I got the final parts for my talion build and I put it out for a test drive and it has a few weird issues..
When you try to take off from a stop at a low rate of throttle there is a lot of cogging or whatever you call it before it starts to go.. unless you give it more then a little throttle then it just takes off.
Another issue it’s having and the main one for starting this thread is a weird power cutout it has if I’m cruising at a low rate of throttle and punch it , it kinda cuts out and does this weird click noise. But if I gradually get on the throttle it doesn’t do the cutout and comes on like a giant turbo.
Car has the max8 combo
2200kv
I have xt90’s on all my arrma’s , batteries I have a few different ones but doesn’t seem to change which batteries I’m using ?
gensacearespammers 50c 4000mah x 2
Lectron pro 50c 5200mah x2
Power hobby 100c 6500c x2
Always run on 6s...
Gearing is 50t/17t
Tires that I was using for the test run were the kraton V3 tires. 3.8’s
I can’t figure this out ?
Any pointers?
Thanks everyone
2200kv
Always run on 6s...
Gearing is 50t/17t
Any pointers?
Thanks everyone
