Senton Weird motor sound. Help.
Lennart
Germany
  1. Senton 3s
I just opened my motor to clean it up. Tested it and this is the sound. Someone help.
If it sounded better before you opened it.... maybe you put some spacers in the wrong location or you just have a bad bearing. But you probably already thought of that yourself :LOL:. Is the motor vibrating more than before when revving up?
1999fd
Greece
  1. Senton 3s
Bearing time..😎.. lucky you caught that before it came apart..
Just checked it again it had a small paper between the bearing and the shaft it's fine now 😂
A small piece of paper did that..
it's alive. Can't believe how important motor cleaning is. If I didn't see that Little paper I would have to buy new bearings 😂
  1. Felony
  2. Kraton EXB
  3. Senton 3s
I would advise you to go ahead and buy a set of jims for it.. its got a lil play in it now most likely, just grab the shaft and see if it moves side to side any!? Preventive maintenance is the key to longevity!! 😎
1999fd
Greece
  1. Senton 3s
Very small shake. Some say it's from factory I've have this for a while and motor runs fine. I've checked the bottom bearing it's fine. Can't get to the top one I'm too weak. Anyways I will probably change to 4s in a year or 2.
