- Brooksville, FL
- BigRock 4x4
- Kraton 6s
- Nero
- Outcast 6s
I’ve been having this problem for a while and have tried everything. My brothers kraton is making a really bad noise. It sounds like gears grinding or something like that. And every time we run it thru it to see if we can get the problem to break itself the center diff always blows. I’ve tried everything I can think of: new center diff, new front and rear diffs, new motor, new esc. Nothing is working. The gear mesh is set properly and the pinion gears into the front and rear diffs seem good. And on the front tires I can spin just 1 or both and no noise. Same with the back. But when you try to spin all 4 it makes the noise. Please help. If needed I’ll post a video as soon as I get it to that point again as I’m waiting for another center diff to come in from Jenny's.
