Barmaleus
Hi folks!
Did a bunch of jumps today, nothing crazy imo - maybe 1-1.5m from the surface. Some runs on the asphalt.
After one of the landings heard that something is wrong (a grinding sound appeared). Eventually found out that a tooth is missing on the pinion gear (16T).
Does it mean I am landing on power or was just unlucky? I do know that landing on power is bad-bad and always try to let go the throttle before the car lands. The mesh was fine from the factory - a tiny bit of clicking between gears, felt good.
Was also wondering if there are any known quality alternatives to the 6s pinion gears (in my case it is ARA310963)?
Thank you!
Thank you!
