philipbeeney
New Member
Hi guys. I’m new at this. What’s this nut called and can I get replacements?
Thank you. I’ve only just bought the car second hand. A kid owned it before and has beaten it up.No idea what you are asking an arrow would help unless @Engineer had the right answer.
An arrow or something in a picture works wonders, simple point to it with a finger or screwdriver if you do not want to edit pictures.
Unsolicited advise,
If this is how you are running, I am surprised that nothing has melted yet or worse caught on fire.
Replace all deans connectors and do not use those screw terminals. You are drawing 100-140A and this is a disaster in the making, they are rated at 10-16A if I recall correctly.
If this is just your trial setup it's ok but I wouldn't use it for bashing.
Unsolicited advise,
That’s really helpful . Thank youCheck out the exploded views on the Arrma website, you can find everything you need:
https://www.arrma-rc.com/interactive-exploded-view/ARA106040T1
youre looking for the pivot ball cap.ARA320467 you will need this too AR330505. You can order from arrrmas site. or just google those numbers. I love how buddy can point out a wire hiding in the background but couldn't see the obvious missing red part in center view.That’s really helpful . Thank you
Forum members, do you recommend the hot racing steering blocks or is there something better out there?
