TeachMeCars
- Granite
- Talion
Its in stock ironically if you live here in the States.Top plate, Steering bellcrank and Ackerman link.
https://jennysrc.com/collections/ar...bellcrank-top-plate-kraton-notorious-ar106048
Hope this helps.
It looks to me like I have the top plate and bellcrank. Could I save some money and just the the COMPOSITE SUSPENSION MOUNT #AR330379 part?Top plate, Steering bellcrank and Ackerman link.
Hope this helps.
Okay I figured it out. I need the AR330379 part and then the other broken part is from the front diff gearbox. Feels good to figure this stuff out!Its there underneath. Jenny's picture only shows the top. You cant see it. I think This is for a Talion specifically???
BTW, yes sir, you may be better off getting the AR330379. If that's all you really need. Your call. Save some $beaucoup$ for sure.
I take it that is part of the gearbox that houses the diff?Looks like you broke the ears off the front bulkhead too.
Good, that's exactly what I ordered earlier.You will need a new gearbox housing as well. As @slick2500 pointed out, you ripped the ears off and that is what keeps the car together.
One like this: Arrma AR310854
https://www.ebay.com/itm/Arrma-AR31...027832&hash=item3d9f14ab04:g:yX4AAOSwdnZaEyU5
Any footage on how this happened?
