Kraton What degree do toe out should a Kraton have?
Slogrits
What is the proper toe out on the front wheels? Over the years of replacing parts I have accidentally removed all toe out. The front wheels are perfectly straight.
I usually do straight to 3 degrees out max its personal preference. Some of my trucks are so sloppy i don't even worry about it.
I would go anywhere from 1-3* out as best as you can. The suspension has so much slop and play in it that you will never get it set perfect.
Bashers have slop. It is what it is. A little toe out on the front, a little toe in on the rear, just eyeball it then let er' eat.
Thanks I will just eyeball it to roughly the same degree the back wheels are.
Think I got it pretty close. Sorry camera is not directly over top. Front roughly matches back. It’s kinda like a rally car set up. Little toe in little toe out with a slight negative camber on the back wheels.
Best tool for the job.
There is slop it makes it difficult making the wheels even.
