Check your straps kids!
At least it didn't rip them off the pack and it's a fairly easy fix.
So that plug is replaceable?At least it didn't rip them off the pack and it's a fairly easy fix.
Yes, just look for jst-xh (balancer plugs) and make sure those loose wires are not touching meanwhileSo that plug is replaceable?
It's the bumper mount. It comes as a 3 piece set along with the EXB bumper and bumper spring. If I were you, I'd get the aluminium standalone bumper mount from Hot RacingI can't find this part without buying a front bumper. I have a skid plate and front bumper coming from RPM but where can I get this?View attachment 188681
Or this one! I didn't know M2C made one tooThis will do! And won’t rip again.
https://m2cracing.net/cars-and-trucks/671-m2c-3595-arrma-6s-exb-front-a-block.html
But the rpm bumper doesn’t fasten into that. Just fyi
It does, but it's a thin plastic piece that goes in front of the stock aluminum front lower hinge pin mount. They give you two with the bumper, which makes it look to me like it is a high failure part. I use the RPM bumper, but I replaced the entire stock front hinge pin mount with the Hot Racing lower front/front hinge pin mount (see below). The HR part works great with the RPM bumper.From what I understand the RPM front bumper now comes with a thingy to hold the pins in the front.
I know I have all of their suspension mounts.It does, but it's a thin plastic piece that goes in front of the stock aluminum front lower hinge pin mount. They give you two with the bumper, which makes it look to me like it is a high failure part. I use the RPM bumper, but I replaced the entire stock front hinge pin mount with the Hot Racing lower front/front hinge pin mount (see below). The HR part works great with the RPM bumper.
https://www.amazon.com/gp/product/B07MC5JFLX/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
And I will someday. I expect to get the HR gearbox for the rear soon, and I will replace the rear/front hinge pin mount when I do that. I'm not as concerned about the front/rear, so that may come later.I know I have all of their suspension mounts.
Here's link to the latest version of the RPM bumper. It shows the small piece that holds the hinge pins in.From what I understand the RPM front bumper now comes with a thingy to hold the pins in the front.
Yeah I have this too. However there is still a gap for the plastic end piece at the bottom. I want to close it off because I increased bulkhead strength with a slightly wider bore and longer bolt fastening RPM bumper, Hot Racing skid plate, and bulkhead to the chassis and tightened it all up.It does, but it's a thin plastic piece that goes in front of the stock aluminum front lower hinge pin mount. They give you two with the bumper, which makes it look to me like it is a high failure part. I use the RPM bumper, but I replaced the entire stock front hinge pin mount with the Hot Racing lower front/front hinge pin mount (see below). The HR part works great with the RPM bumper.
The bulkhead/gearbox is the only HR part I don't have that can possibly be installed on my Senton. Haven't seen a need for it yet as the bulkhead covers and the way I've secured the bulkheads strengthened up the composite bulkhead beyond my expectations.And I will someday. I expect to get the HR gearbox for the rear soon, and I will replace the rear/front hinge pin mount when I do that. I'm not as concerned about the front/rear, so that may come later.
https://www.rpmrcproducts.com/shop/bumpers/front-bumpers/kraton-6s-front-bumper/
