- Talion
- Typhon 6s
Got enough o-ring grease for $15 to last the next 10-15 years.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I've used them for a couple years now, won't use anything else on my 3s rigs!!I’m interested to hear how good this is. I’ve been eyeing up another K4 at the LHS, and the plastic servo savers are crap.
Bought this little guy. Gonna give him a shot!
I'll do a comparison to the max10 sct, which I suspect is basically the same thing.
a set of Porkline Mirage TT tires on the dreaded Raid wheels.. hopefully the hex adapters hold up. This is a big step since I haven't purchased any Porkline tires in like 25 years..![]()
I received this order today. I need to order bigger carts from Jenny, their S/H is painful on small orders.
I know.. then either pony up another $80 for Porkline's aluminum adapters or $50 for chinesium ones from AliEx.. like I said against my better judgement I bought these. Thing is, I'm really desperate for some good traction on my clay track with Mojo sized tires.. they're going on my Typhon XL (Mojo armed Kraton) truggy mini pins work great but too wide, and too fragile for 6s power.. what's a fella to do@KnowAir .. you know you're going to regret this purchase.....To answer your question, if you run 6s no the hex adaptors won't hold up..!!
Nice! I have a set of Eklind T-handles from Homer Depot that are quite handy. The best part is the entire length of each hex wrench is hex shaped..round one off? Out comes the 4" grinder, grind off a wee bit to make new again. Sweet.ordered some teng tools t handle ball ends from 2.5mm to 8mm
So, looking at the included adapters with the Mirage TT wheels, I'm thinking you use either or? Meaning plus offset or zero? I'd think the positive or plus offset are the susceptible pieces? Hoping I'm right and using zero offset adapters will negate breakage.@KnowAir .. you know you're going to regret this purchase.....To answer your question, if you run 6s no the hex adaptors won't hold up..!!
