- Location
- Tauranga New Zealand
- 4x4-Mega
- BigRock
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Outcast 6s
- Outcast 4s
- Senton 6s
- Typhon 6s
- Typhon 3s
Senton 3s in green
I don't get it.Had to run to Wall today so we decided to take a slight detour to Wall Drug.
Picked up this and a tshirt, both tye dye.
Wall Drug is a tourist trap. They have a sign in Antarctica.I don't get it.
I saw that sign also, when I last vacationed in Antartica.Wall Drug is a tourist trap. They have a sign in Antarctica.
It's ridiculous people even put up their own signs. In a 1 mile stretch of interstate that I frequent for work there are at the very least 6 signs for this place.I saw that sign also, when I last vacationed in Antartica.
It doesn't fit......................If this thing runs at 250* after 5 min I'm selling the Outcast.
I was there about 17 years ago. Is that giant dinosaur still there?Wall Drug is a tourist trap. They have a sign in Antarctica.
Yup, they added red leds to his eyes, super creepy at night.I was there about 17 years ago. Is that giant dinosaur still there?
This is what I was thinking at least a 3mm spacer under each point on the motor and diff mount.Couple of spacers under the center diff mount..??
I think the 49 mm diameter motor's can is too fat IMO. You would have to somehow raise/change the motor mount for this can to clear the bottom of the chassis. the length will barely clear the chassis side guard however.It doesn't fit......................
To gain clearance, you have to raise/Shim the whole center diff and motor mount as an assembly. I imagine it could be done. Someone has done this for sure. Anything is possible. But this 4985 can is not a shoe in. But a torque monster it is. And should run cool at 1650Kv.Couple of spacers under the center diff mount..??
Nice score.Big Boys With Cool Toys in Toronto is having a 15th anniversary sale. Dropped in yesterday and grabbed a bunch of parts and two new bodies (buy one get one free for the bodies).View attachment 46456View attachment 46457
Yeah my plan is to raise up everything, unfortunately the LHS closed before I got off work, and the hardware store closed right as I got there so I didn't make any leeway on this. And I swear either @bicketybam or @Mr.Duke have this motor in one of their Arrmas, I do not recall any of them needing mod anything.I think the 49 mm diameter motor's can is too fat IMO. You would have to somehow raise/change the motor mount for this can to clear the bottom of the chassis. the length will barely clear the chassis side guard however.
I just did some quick measurements on my Noto. There is less than 4mm clearance between the chassis and motor with the OE BLX motor/motor mount.
Just delivered. My old one got worn out. This one can handle 1/8 scale too. And fit a diff as well.
View attachment 46460View attachment 46461View attachment 46462View attachment 46460 My new pump. Old one was worn out. This one does 1/8 scale too. Hudy makes an electric 1/8 version one at 3 times the price and has been on B/O. I stayed with the Tamiya brand. My old Tamiya pump lasted quite a while. Hard to find in stock. AMZ had one left. And I scooped it up.
Has anyone else been using a pump?
I am currently running the Hot Racing mount not the stock og mount.@slick2500 You can either run the v4 motor mount or shim the v3 mount and center diff with spacers. The v4 mount doesn't need shims to run this motor.
I run the v3 mount shimmed because of how I have my cooling fans mounted for easy maintenance and removal using existing holes for the side guard to mount to the chassis
On the new v4 mount, there's a small kick out that the v3 mount doesn't have. I would need to machine that off in order to run my fan setup and do away with the shims for the v3 mount.its been rock solid with the current motor mount so I haven't bothered modding the v4 mount yet. I eventually will though
You'll also need to trim the rear of the side guard to get it to fit properly View attachment 46533
Also go ahead and put a small piece of gorilla tape over that temperature port on the back of the motor to keep dirt out.
