Ahhh. I
Yeah, i'm going to be selling them soon. I know I have said that like 4 times within the month, but I have my reasons.Ahhh. I
I never did let it get wet. Always in a sealed bag with disectints. I guess it wouldn't hurt to dry it out too. Do you have a link to a dehydrator I should get?Try to hone in on your quality when the prints are how you want them design and fit wise.. your filament looks moisture soaked.. try drying the spool in a dehydrator for a couple days or throw it in the oven for a few hours at like 170 degrees Fahrenheit.. dry filament is a more precise filament..
Okay, thanks, but i'm not using TPU. I'm using a different "secret" material.Any cheap dehydrator will work... Just cut the centers out of the racks.. leave one complete for the bottom rack to hold the spools..
Issue with sealed bags is you open them.. filament instantly starts to absorb water even right off the machines from the factory.. the small packets don't really work once it's been opened to air several times.. I dry all my tpu before using it..
Rookie here. What are the signs that filament needs drying?your filament looks moisture soaked
Thanks foe the detailed response! I think I have some drying to do.There are a couple signs of moisture soaked filament that you can look for..
Excessive fine stringing..
Popping noise from the nozzle, listen carefully as it is extruding
Physical steam release while popping. Seen more in the nylon side of materials.. abs,asa will react the same
Brittle material, pla is most common for this.. once moisture soaked it becomes brittle and will snap very easily.. sometimes pla will not come back from this state if it's had major moisture uptake..
Airy looking prints.. looks more like a under extrusion.. nylon based material is more prone to this and will be quite obvious..
Extremely poor over hangs, given your print settings are correct, overhangs will suffer more while moisture soaked..
It's best to dry any and all filament before use.. the desiccant in the bags is typically already spent by the time it gets to you..
Are you selling a lot of bumper supports? I think I'd sell mine faster if I put them on ebay.Wing mounts and bumper supports all day every day
Between what I have given away and sold. 3Are you selling a lot of bumper supports? I think I'd sell mine faster if I put them on ebay.
I think I have sold/sent for testing about 5-8.Between what I have given away and sold. 3
