What did you work on today?
Those wires on the battery cables look a bit small. What size are they?
Wanna say 8 awg. I think thats what Hobbywing has installed.
Should be plenty. Higher S equals less current.
Report back though, my guess, you won't need fans on the motor due to significantly less heat being generated at higher voltage.
I run a max4 in my other Outcast and it has the same awg power wires. Never any issues. Max5 g2 in this though so we'll see. The max4 outcast needed fans but im running 39/39 on the gearing. I went with 35/39 on this one. Ill run it soon. Let you know! 👍
I don’t see a problem with running the fans you have them run them cool rig
Thanks! 👍
I definitely wanted fans either way.
I run fans on all rig secondary battery 2028 8s large pinion gear
Wow, Assuming the ESC's wires are 8, the ones on your battery plug look much smaller.
Nice looking chassis. Should run a long time on two 6s batteries.
The The typhon 111mph and the 8s Mojave GT I’m still testing have a few things to work out
Further mock up and test the drive train, After a rebuild and fitting the max 5 G2 1100kv combo with some new shoes, just waiting alloy centre, and bulkheads, uprights to arrive, looking at the infraction body this looks interesting and could be made to work.
'm going to test on these tracks if permitted. both should be interesting here.🤔
I'll be testing these DXF packs that I picked up cheap, they seem to do ok on a first test on a stock truck, Anyone else tried them?
A little footage of the day
your last post you where going to check out those tracks 🤔
Yeah I went to one it's a 400mm track some footage of there in the outcast from entering and in and around part of the track it's also got a 2 mile track around park pretty cool, to be fair with more than enough grass on either side with some woodland areas to add, The day was cut short as the weather turned out bad in the end.
But will be returning soon hopefully on another dry day and see if we can get some 400m oval times on a few cars.
Nice spot ! Having the rest working ground is half the battle when you can just leave your build as is and go back to it in the same place ... chicken dinner I'm still working day by day night by night on a kitchen worktop.
