- South Louisiana
- BigRock 4x4
- Granite
- Kraton 6s
- Mojave
- Notorious
- Talion
- Typhon 6s
I do it on purpose now. lolSo in other words, you spend a lot of time on you roof ? ?
Can't get at the hex on the end of the filter when it's installed?
Ahhhh...I took a closer look at the pic and can see where the hex got munged up.
First oil/filter change? I've seen factory installed filters that were on crazy tight.
I started fixing my Jeep headlights that have been neglected for years. Trying the ChrisFix method before dropping $400 on a new set.
Doing it one at a time. Got it ready for clear and it started raining. Will work on it tomorrow
$30 ain’t bad. I think I have $10 in some sandpaper and some clear gloss in a rattle can. If this doesn’t turn out I will order that kit. ????
Let me know if you can’t get it. I have an account with Wurth. I’ll get ya a kit.$30 ain’t bad. I think I have $10 in some sandpaper and some clear gloss in a rattle can. If this doesn’t turn out I will order that kit. ????
I hope to finish up tomorrow and will let you know. Thanks man. You’re not so worthless after all ?Let me know if you can’t get it. I have an account with Wurth. I’ll get ya a kit.
? I have one at work. Pay for shipping and it’s yours ?
That is the way I have always done it, you can't use cheap clear though you have to use a good high quality enamel otherwise it fades after a couple of years.$30 ain’t bad. I think I have $10 in some sandpaper and some clear gloss in a rattle can. If this doesn’t turn out I will order that kit. ????
You washed it with beer?So woke up today to find the clear is cracking? Is this due to inferior quality? Maybe temps were too low (50ish F)? Too much humidity? The lens was washed with IPA and allowed to dry. Then I used a heat gun to ensure it was all evaporated. Then put down 3 coats and hour apart.
I was thinking the same thing lolYou washed it with beer?
Isopropyl Alcohol = IPA ????
Guess I will wet sand it again and start over. I will admit I tend to over apply. I can’t help myself.
