Granite What diff oil do you use for bashing with the granite 3S?
shingo
Montreal
what do you use for the granite 3S ? I need to change the diff fluid but I’m wondering if I can improve over the stock 10k for my bashing session.
How do you want it to improve? If you want less wheel spin up front, go heavier up front. Going too heavy in the rear is going to make it tonight to turn under power. Being that it’s a Granite and not a track car, this probably isn’t that important to you. I would think the max you would want to go is 50k cst.
I went 10k stock. I had to add a little since it's a bit low from factory. It's fine for bashing I would think (10k)
I don't like running anything to heavy up front. I like my trucks to turn ? The most *I* would do is 20k in the front or rear. YMMV.
I would just like my front tires to touch the ground ??
Throttle control, bruh ???
