Outcast What does this mean?
Spanky08
Hi I acquired a outcast today with battery’s but get this message when I try to charge???
See attached picture
I highly suggest getting a separate lipo checker so you can always cross check. This would definitely help with your current situation. I prefer the spektrum esc programmer as it has a balance checker built in and you can also make changes to the esc.
Too much voltage difference (delta) between cells (more than 1 volt). Some chargers won’t attempt to charge due to said difference.
Likely one cell is dead or on its way to be dead. Your charger should have a voltage meter, and you should be able to see each cell’s voltage.
