Fredr3x
Hi guys, was looking to buy a Kraton 6S EXB, but figured I could get the 8S. What would you recommend? Thanks!
Thanks for the help man. Is the 4985 - 1650 for the 8S? I have decided I am gonna buy the 8S EXB. Also, what servo would you go for? Thanks againI am not an expert, but I know that the Max 6 is good for a (was) 6s EXB it is a small 8s set up but a big 6s set up. I would do the 4985 SL-1650KV. if you don't want to pay that much here is a 6s from Spektrum https://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMXSEMC05
Also you can find a nice deal on eBay for a new combo or used.
https://www.ebay.com/itm/384414157659?epid=7033383431&hash=item5980de8b5b:g:oMkAAOSw7yJhHsw4
The 4985 SL-1650KV is 8s But I would get theThanks for the help man. Is the 4985 - 1650 for the 8S? I have decided I am gonna buy the 8S EXB. Also, what servo would you go for? Thanks again
I really appreciate that. Not entirely sold that the Kraton 8S is capable of 204.3mph, but hey what do I knowThe 4985 SL-1650KV is 8s But I would get the
5687 SL-1100KV since it has more torque. even with the 1100KV motor theSpeed Calculator said 136.2MPH with the 1650KV... 204.3 . the Max5 is a tank setup but it is $349.99. this is the stock setup for a Arrma 8s and it is good. https://www.horizonhobby.com/produc...1250kv-sensorless-motor-combo/SPMXSEMC06.html
https://www.ebay.com/itm/403183425090?hash=item5ddf9ad642:g:M54AAOSw8z1hS-3U
the firma 160a brushless smart esc / 1250kv sensorless motor combo is = to the Max6 combo. I don't know much about servos, this is the stock on for the 8s line SPMS905, here is a deal you can't pass up it is from Jenny's
https://jennysrc.com/collections/kr...arrma-blx-1-5-ar110002?variant=31625757425718
https://jennysrc.com/collections/kr...-firma-spektrum-spmxsm1205-arrma-1-5-ar110002
https://jennysrc.com/collections/kr...60a-arrma-1-5-ar110002?variant=31625676128310
https://jennysrc.com/collections/kr...-d5-arrma-1-5-ar110002?variant=31625704505398
again I am not a pro at this,
TN-RC
PS: have you met Kevin? (being that it says "Kent, UK (Local Track Paddlesworth)" for your Location.
