Asking for a friend.
Ive started with mmx6s/tp4250... now running mmx8s/tp4070 and a jx 36kv 7.2v servo. She's a beeeeeest! https://www.arrmaforum.com/threads/grimbles-mojave-exb-build-thread.29151/Asking for a friend.
Max6 4985 1650kv comboAsking for a friend.
Think you could run this on 6s or 8s. Castle XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXLX2 recommended.Asking for a friend.
This will work fine!
Yep, this will work, if you can get itMax6 4985 1650kv combo
Hi and welcome to the Arrma Forum. The forum has an excellent feature in the top right of the screen for searching through the thousands of threads available. To help you out, I'm attaching a short cut that might help you with your query.Asking for a friend.
And if you get the Traxxas link module and a TQi transmitter, you can turn it down even more in the app!View attachment 140094
And it is waterproof! I would recomend running it in training mode. Might be too fast at 100%
https://www.arrmaforum.com/threads/mojave-exb-speed-run-build-sheet.37028/Asking for a friend.
You aint lying there... I'm already filling up a shopping cart. Shims, fasteddy bearings, PPS-RC gear, batteries.You’re going to want to consider getting scorched fenders and / or a dust cover. They are a little pricey....nothings free you know
Be sure to add the promo code "arrmaforum" at checkout for an extra 25% off! (If this works, pm me and I'll get shopping right away)You aint lying there... I'm already filling up a shopping cart. Shims, fasteddy bearings, PPS-RC gear, batteries.
From what I understand the new sealed bearings aren't that bad.You aint lying there... I'm already filling up a shopping cart. Shims, fasteddy bearings, PPS-RC gear, batteries.
On par with fast eddy imoFrom what I understand the new sealed bearings aren't that bad.
