So i been running my Notorious hard recently and start to get safety cut off due to motor temp (stock set up).
Can anyone recommend a fan/heat sink combo i can throw in please?
This is what I run on mine:
https://www.ebay.com/itm/Powerhobby...or-Heat-Sink-W-Dual-Cooling-Fans/392518613703
I swap the fans out for these though:
https://www.rcjuice.com/hobbystar-turbo-ventilator-esc-motor-fan-30x30mm-red.html
Have to grind the little holes on the bottom of the fans a bit because side by side they are a bit too wide, but was able to make them fit. I also used 2mm spacers under the fans so they could breath better.
2mm version of these:
https://www.rcjuice.com/hobbystar-aluminum-spacer-10pk.html
I put the screws through the fans, the put the spacer on the screw and crimp it a bit with pliers so they don't fall off when I'm mounting the fan.
Also used this stuff to cover them:
https://www.amazon.com/gp/product/B077M93J18
I just ordered another and fans for my ERBEv2. I have a blx2050kv in that as well.
That pinion has some hours on it! Might be a good idea to get a new one on order.
