What heatsinks are they running on hobbywing 1650
What HobbyWing motor are you referring to? The only “1650“ designation with HW that I’m aware of would be the EZRun 4985SL (1650kv)
The threads mentioned above are for that motor. The only one that would fit would be an x-maxx one
what about the Kraton 8s? That one is also listed as 49mm diameter. Not a bad option at $35 for fan and heat sink if it fits.
The hw is 3mm bigger. Might be able to make it work but not a direct fit.
Yup, motor is 49 and heatsink is 46. Read it wrong someplace. Thanks for the correction.
The 4985 SL 1650kv motor is listed as 49mm diameter on the HW website.
https://www.hobbywingdirect.com/collections/ezrun-max-brushless-motors
Yes I have both. The spectrum is only 46mm. Look at the Arrma website. The fins on the hw make the 3mm difference. You might be able to mod the mount and zip tie it.
Yeah I read the diameter of the heatsink wrong somehow, must have flipped the 6 into a 9. Thanks for catching that, I hate spreading bad info.
