https://hot-racing.com/?partnumber=ATF117XT02;c=1407What hub extensions are out there for the arrma typhon 3s blx? New to the site. So im sorry if this thread was already posted
Those won’t work with the Typhon axles. You have to have the threaded axels for the Granite, Senton, or BRCC to use the HR hexes above.https://hot-racing.com/?partnumber=ATF117XT02;c=1407
These are the only ones I know of... I haven’t used them myself but they are supposed to be really good from what all I’ve heard.
Ooooh okThose won’t work with the Typhon axles. You have to have the threaded axels for the Granite, Senton, or BRCC to use the HR hexes above.
I don’t know if an extended hex for the Typhon 3S to be honest. I am considering making mine more narrow for speed running. I’m thinking of using the Granite arms instead.
The threaded axles look like thisOoooh ok
Wait what’s a threaded axle? I have the HR driveshafts so am I good for a just direct mount for those hub extensions on my BRCC or no?
So u saying I cant use the factory wheels with extension set up?I have these and they are really good, although I did loose a nut from my own stupidity...
Just a word of warning for anyone else looking at these, they are an extender (+10mm) and an adapter to 17mm so you will need new wheels as well (Proline Badlands PRO10125-18 work well). Just an FYI
The Typhon 3s factory wheels use a 17mm hub pattern so they will work with the hot racing adapters / extensions. The other 3s Arrma trucks use a 14mm wheel hub pattern so most of the time this adapter is used only to switch to different aftermarket wheels/tires.So u saying I cant use the factory wheels with extension set up?
That's what i thought. Ok cool thanks 4 the reply.The Typhon 3s factory wheels use a 17mm hub pattern so they will work with the hot racing adapters / extensions. The other 3s Arrma trucks use a 14mm wheel hub pattern so most of the time this adapter is used only to switch to different aftermarket wheels/tires.
These look so much more durable than the Granite axles. I snapped another today. Can I use them on the Granite? What do I need? Typhon arms, rod ends/turnbuckles and hexes?The threaded axles look like this
The Typhon axles look like this
There's no way to fit stock 14mm granites wheels to typhon axles. To use Typhon axles you need 17mm hexes and 17mm hex wheels/tires. If you're using hot racing adapters with granite axles already to run 17mm wheels then just swapping to typhon axles and hexes is all you need to do to switch. You will lose some offset but that's it.These look so much more durable than the Granite axles. I snapped another today. Can I use them on the Granite? What do I need? Typhon arms, rod ends/turnbuckles and hexes?
*Just found it on another post. Looks like this will work.
