Cwbyup19781
Hey gang hows everyone doing? I have a stock kraton 6s blx i would like to upgrade the motor from the stock 2050kv to probably an ez run max brushless 4985SL 1650Kv. Would this be a good alternative for the stock and be able to put a bit more torque behind the tires? Could i go any lower, for example to an 1100kv without screwing up my esc? The esc is also an upgrade i just got it today in fact. Its the ez run Max6. Also upgraded the servo to a powerhobby 729mbl high volt brushless steel gear high torque with aluminum case. Any suggestions or recommendations and maybe some tips, DOs and DONTs would also be helpful thanks yall
