https://www.amazon.com/Servo-Waterp...child=1&keywords=DS3225&qid=1606182358&sr=8-4Can anyone recommend one?
Mine died
Thanks for the heads upDo note that the Spektrum servo is 23T so you either need to replace it with a 23T servo or get the 25T servo saver AR340151 https://www.arrma-rc.com/part/AR340151
Stupid 23t ??Do note that the Spektrum servo is 23T so you either need to replace it with a 23T servo or get the 25T servo saver AR340151 https://www.arrma-rc.com/part/AR340151
S6230 is a 23 spline output shaft. Per the specs.Turns out the 23T servo saver does not fit in another spektrum servo.
Anyone knows how to fit in a S6230?
Hmm, do you know what sort of horn fits into such shaft?S6230 is a 23 spline output shaft. Per the specs.
I never likes spektrum servos
Thanks for the quick reply ! I guess I'll be waiting for the arrma one to get back in stock in eurorc.com website or maybe if the hot racing is in stock. Would that be better or worse than the arrma one?Modded Kimbrough 124 is your best bet at this point in time if you want to get a non Spektrum servo.
Fortress RC Part # FRC302Can anyone recommend one?
Mine died
Fortress RC part # FRC302Can anyone recommend one?
Mine died
I just got this servo for my Senton and can't figure out how to attach it to the existing arm. It looks like the round peice will fit into the old servo save top but I can't get the old one out. The shop said to use the arm that came with it not the servo saver but the screws don't attach from their arm to the truck arm. So frustrating. Any pictures of how you made your work or a video install link etc?Fortress RC Part # FRC302
