Raider What is causing handling issues in the loose stuff for Raider XL BLX?
This was what ic-racer on rctech.net had to say.
"If you have 3 channels, the third channel can control the gyro gain from the hand-held transmitter. Crank the gain up until the car oscillates when it hits a bump, and then back if off from there; it is very easy to get it set just right. Once set, you don't have to mess with it. "
Oops....haven't looked at my Slash for a long time...these are the adaptors...
https://www.ebay.com/itm/Hot-Racing-WH17HS01-6mm-Offset-17mm-Hubs-12mm-Hex-Mount-New-/321782743101
I was running MIP CVD's but not the MIP 17mm adaptors as I read on a forum that they caused binding issues. These were compatible with the MIP CVDs and worked flawlessly. Also looked pretty sweet.
Again, not sure if they would work for arrma granite/raider
Awesome. Do the adapters have slots in the back of them for the cross pins to fit in them?
