Hi guys so I’ve seen some 27T arrma mod 1 pinions online but some have a “SafeD5” in the title. What is safeD5? And will it fit onto the Typhon V5?
cheers
cheers
Yes as the stock V5 motor comes with a SafeD5 pinion.Right thanks for info… last one.. will that 27T mod 1 safeD5 fit onto the stock motor for the typhon v5? Spektrum Firma 4074 2050Kv Brushless Motor?
Cheers
Cheers!Yes as the stock V5 motor comes with a SafeD5 pinion.
Making the motor match the pinion rather than the other way around is a bad idea: motors are a lot more expensive than pinion gears.Stock motors will work just fine. All others motor shafts have a little 'lip' at the front that will prevent the safeD pinion to be installed. Motor shaft cod be dremeld into submission though.
