Typhon What is the connector from the esc to the motor?
Kratonage
Vegas, NV
  1. Talion
The esc issues mount with arrma. Second run on my typhon and the esc fan is now missing a fan blade. What replacement esc has the same connector for the motor? Hobbywing esc max8 hopefully? Or maybe replacement esc fan?
The connectors between motor and esc look like "normal" 4mm bullets to me. Had the same issues with my fan, after 3rd run or so one blade was missing. found a little stone inside the esc which killed the fan.
Replaced it with a Hobbywing Fan HW86080070 (was the only fan in stock at my LHS) Not exactly the same plug, but with a sharp knife an shrink tube around it worked like charm.
The connectors between motor and ESC look like "normal" 4mm bullets to me. Had the same issues with my fan, after 3rd run or so one blade was missing. found a little stone inside the ESC which killed the fan.
Cool ill keep that in mind gatno!! Thanks for your help:cool:
