I'm curious to see the replies/suggestions; having a Raider I'm assuming our battery bays are the same size and I've been concerned with finding a LiPo that will fit.What kind should i use
I like SPC and SMC LiPo batteries, there are several brands out there. You could go get a super cheap Turnigy 2S LiPo.What kind should i use
I stuffed the 8000mAh 40c Floureon in my GraniteThis fits: 4000mAh
When you say you can run a LiPo, is that in a stock, out of the box truck, or is there more upgrades before you can do it?@mapehole Yes you can run a LiPo in the Vorteks.
Yes you can use LiPo batteries in a stock Vorteks. You will need to move the jumper on the ESC - see page 7 of the Vorteks manual.When you say you can run a LiPo, is that in a stock, out of the box truck, or is there more upgrades before you can do it?
Hey, thanks.Yes you can use LiPo batteries in a stock Vorteks. You will need to move the jumper on the ESC - see page 7 of the Vorteks manual.
U can run 2s not 3sCan i run a 2s lipo 3000mAh in an Arrma Vorteks?
I run 2s lipo out of the box heaps farsterWhen you say you can run a LiPo, is that in a stock, out of the box truck, or is there more upgrades before you can do it?
