Felony What motor/ESC combo is it?
  1. Infraction
  2. Kraton EXB
I have a stock motor/esc combo out of a Felony I used to have that I had upgraded and sold. I just scooped up a Losi LMT King Sling today. It has a Spectrum 130a ESC in it that is capable of 4s apparently. I am thinking about putting the Felony motor/esc in it. Just wondering what the Felony set up is equal to in the Hobbywing "version". Max8?
Kinda sorta. max8 has more functions you can program. I run the max8/2600kv setups on 4s in my lmts. It's mental on a 16t pinon which is the largest mounting hole on the motor plate. I would say go for it, you'll gain torque for sure. I'd run 4s and a 16t pinion and see how it goes.
Thanks! 😃👍
I'm guessing 6s would be just stupid and probably won't fit in the battery tray, correct?
This is one i sold with the max8/2600kv combo in it
Thanks! 😃👍
I mean you could probably make it happen but it would be a fliping machine hahahaha. I would have been fine with the 2200kv motor in mine. You can run an aftermarket lcg battery tray that might fit the 6s battery but 4 is def plenty. Only bad thing about the lmt is spending as much on the aluminum axle housings as the truck itself :ROFLMAO:
Sick... I can't wait to upgrade it and blast! ☝️😃👍
Oh snap i saw you got the king sling and not the lmt. those wheels def hook up more than the monster truck wheels. I have two trucks running the jconcepts fling kings and if you have your brake set to 50% it'll do a front flip when you get on them hard hahahahaha
I actually want get the jconcepts monster truck tires. I love the look!
Should be fun to have both!!!
I am so pumped. I had a Clod Buster as a kid and it was my favorite. This is like one of those on steriods! 💪
Here’s my 4
Have you looked a the treal parts for the lmt's?
They can chew up servos as well. I have treal servo savers on 2 and I’m trying this with an air dampener and a servo af saver
I have... they seem awesome and a bit cheaper then the Vitavon ones. I have a Treal steering rack on my Krajave and I am very happy with it. I'm sure eventually I'll have every stick that they sell for this truck so I can actually bash it. 😎
Have you seen my Krajave build??? I go all out! 😆
Right on, you can run the stock axle housings til they fail, but with it getting colder out that may end up being sooner than later. The wheelie bar on the back is kinda cheesy too. I got a 3d printed one from kenny downs on the fb page. Steer clear of the stainless front bumper. It's good at one thing and that's bending your chassis. I know the lmt and mega trucks are a little different but not sure besides links and possibly shock locations what all is different with them.
I would have got the Son of a Digger but I got the King Sling at my LHS today Black Friday/Open Box (they ran it once to test it out) for $399! For $250 off I couldn't say no! I've wanted one for a while.
Another option if the truck seems slow on 4s might be to snag a 4s kraton motor off jennys. It'll give you a little bump in rpm. https://jennysrc.com/collections/kr...4-motor-firma-2400kv-4-pole-bl-3668-ara4408v2
No doubt! i bought a roller to use for parts and ended up using all aftermarket stuff but the diffs on the red/gunmetal truck so i have a whole roller left in the box i'm debating on building or selling. They had the rollers on sale for $250 earlier this year before they discontinued them.
Well, I already have the Felony combo so I'll probably just roll with that...
Right on, just an option if it seems slow on 4s and you don't want to jump to 6s on it. If i build the roller i'm thinking i'll use that and the 4s kraton's esc which i think is only 120a. I used the 130a out of the used lmt i bought on a big rock. I won't do the treal bits though and just run it stock and do all the dumb stuff i can't bring myself to do to the treal trucks hahahaha.
Do you know what the King Sling ESC/Motor combo is in hobbywing? It's 130a esc and a Firma 3668 2800kV motor... I guess it handles 4s but I perfer to have a bigger set up then my battery.
They used to say the blx stuff was rebranded hobbywing with less programming options and i want to say some still say that about the spektrum stuff but i think they said the hobbywing program card won't work on it. I bought a spektrum one to tune the few i run. Being 130a it's going to be close to the max10. the max10 g2 is 140a now, max8 160a, and we'll see if they up the numbers on the next max6 version.
Ha! I don't blame ya... I don't care what I spend on my stuff. I build them to beat them! 😆
I always think i will, then i think about what i've got in them hahahahaha. I don't really have any crazy jumps or anything. Most of the time i just rip around in the gravel. May build a typhon out of stock parts to set up a little dirt track in the grass in front of my apt. It's all dead right now so it isn't like i'm tearing it up! hahahaha. Ready to have a house with a couple acres again for sure.
The spektrum 150a is equivalent to the esc below the max 8, The quicrun or whatever it's called.
