Senton What motor?
Marcogarcia
4x4-Mega
Hi guys
I’m new in this rc world and a lot of questions
I have a senton mega, Hobbywing esc sc8 120a, 2s and 3s but I haven’t motor!
Some suggestions?
Thank you so much!
Mentolio
Dirty Jersey
Granite
Yes you can use a 5mm shaft with the stock spur, you will just need to source a new pinion gear that fits the 5mm shaft, and is 48p.
Marcogarcia
4x4-Mega
Good to know I’ll try that!
Thanks a lot!
Jerry-rigged
Have you seen my LVC?
Texas, Baby!
4x4-Mega, Kraton 6s, Outcast 6s, Typhon 6s
hattrick300
Indiana
4x4-Mega
The hobbywing setup that Jerry posted above is a beast! I have it in two of my Granite 4x4's and I love the power........up until it breaks stuff...But depending on what batteries you are running you may want something with less KV's. What are you planning on using, 2s or 3s batteries?
Marcogarcia
4x4-Mega
I have 2s and 3s. I’m thinking in 3500kv or a 3660 3300kv what do you think?
Thanks
Jerry-rigged
Texas, Baby!
The HW 3660 is only available in 3200, 4000, and 4600 (or 4800?). So if you plan on 3s at all, get the 3200kv.
The 3652 is available in other KV's, though. The small motor will be nicer to your batteries also. The 3660 will need good batteries, best to get 50c or better. The 3652 could get by with the cheaper 25c-35c, probably.
TnArrmaFan
I Control Cars Remotely
Tennessee
Granite, Nero
What type of speed do you get out of those as an upgrade to the stock motor in your Granite 4x4's? And what batteries are you running?
Marcogarcia
4x4-Mega
Great informations Jerry, both are 50c!
Thanks
Marcogarcia
4x4-Mega
My rc is an senton mega and I have 2s and 3s, esc sc8 120a!
Thanks
Create account
Log in
Mr.Vylan Senton Bearing extraction (Arrma 3S BLX Aluminum Fixed Motor Mount) Arrma 4x4 2
Antoine morris Notorious Free castle motor from friend RC Build Logs 16
4 Typhon 6s Motor Fan? Arrma 6s BLX 6
06redssr Typhon Who Sells 6s BLX Motor Bearings? Arrma 6s BLX 6
Similar threads
